Problem with Chrysalis pack and MorphOS 3.20
    Papiosaur
    Posts: 2551 from 2003/4/10
    Hello,
    maybe you have Chrysalis pack installed and you have updated your MorphOS system with MorphOS 3.20.
    Seems there are troubles with Chrysalis pack.
    MorphOS 3.20 come with new FLAC Reggae classes in MOSSYS:Classes/Multimedia/ and Chrysalis pack had now obsolete FLAC classes Reggae installed in SYS:Classes/Multimedia/
    Thanks to delete old FLAC.decoder and FLAC.demuxer in SYS:Classes/Multimedia/
    Chrysalis pack is considered as "obsolete" and replaced by Easy2Install.
    If you have others troubles with Chrysalis pack and MorphOS 3.20, thanks to post here.
  • »05.06.26 - 11:08
    Tomtom76
    Posts: 43 from 2021/6/26
    Hello Papiosaur.
    Is it possible to download even an old (any) version of Chrysalis pack please ? It is not for installation just education purposes. If I had before the iso inpacked on my Work partition I could see and learn where/how particular items should be placed on my real working system. Unfortunately one day i reinstalled my HDD and lost the pack. Not always everything is so clear for me so it would help a lot. Thanks
    Powerbook G4 A1106 MorphOS 3.19 & MacOSX 10.4
  • »05.06.26 - 12:03
    Tomtom76
    Merci beaucoup Papiosaur
  • »05.06.26 - 13:34
