Ideas of new projects for MorphOS
    Papiosaur
    Posts: 2615 from 2003/4/10
    Hello,
    I would like to improve my programming and SDK knowledge for MorphOS.
    I would need ideas for projects that are missing from MorphOS (port of game, engine, software, shell command, creation of tool, GUI, etc.)
    Thanks for your feedback.
    Don't hesitate to support my projects on MorphOS-Storage
  • »25.10.24 - 15:55
    Primax
    Posts: 220 from 2021/7/2
    Honestly, I am missing the support of some kind of AirPrint support. If you run MorphOS, having an Canon printer, you are lost...
  • »27.10.24 - 16:47
  • esc
    esc
    Posts: 160 from 2013/5/27
    Hi Papiosaur, I have tried using DCTelnet for Amiga on MorphOS but I think there was an issue with dos.library maybe? In any case, a proper BBS client would be great!
  • »27.10.24 - 19:25
  • esc
    esc
    I think I'd do SyncTERM if I were you - syncterm.bbsdev.net - alternatively icyterm is great (and port the other utilities there as well like the ansi drawing program!) - https://github.com/mkrueger/icy_tools
  • »28.10.24 - 00:38
    Posts: 2220 from 2003/2/24
    DCTelnet has been working quite fine here, at least when running on an 800x600 screen. IIRC it gave some issues on larger windows/screens. I think I've been running 1.6/060 compiled exe, but I'd guess version doesn't matter that much...
  • »28.10.24 - 04:23
    Papiosaur
    @esc:
    About icy tools, i need a compilator for Rust langage...but don't exist on MorphOS i think.
    About SyncTerm, i need a CMake tool more recent (3.11 mini)
    Maybe i could try to port Talisman with libs from MorphOS SDK?
    [EDIT] Seems i need libssh headers to port Talisman: callback.h, libssh.h, server.h not found in the MorphOS SDK
  • »28.10.24 - 05:16
  • esc
    esc
    Talisman is a BBS server, so it'd be a totally different thing, but it would be amazing if it is able to run!
  • »28.10.24 - 23:38
