Open a file at line X with FlowStudio
    Papiosaur
    Posts: 2612 from 2003/4/10
    Hello,
    i see in the Guide it's possible with AREXX but i don't know the AREXX command line.
    Somebody could help me please?
    [EDIT]
    If i write this command:
    RX FLOWSTUDIO.1 OPEN sys:MorphOS.readme LINE 10
    It say: Arexx server is not active... but CRABUM need AREXX work...
    i dont' understand...
  • »25.09.24 - 10:25
    Posts: 2219 from 2003/2/24
    With RX you would need more code there, but use the RXCmd command, which is easier and doesn't need functional ARexx environment either.
    RXCmd FLOWSTUDIO.1 "OPEN FILE sys:MorphOS.readme LINE 10"
  • »25.09.24 - 13:50
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    Little Arexx
    /* Show(P) Return Ports */
    ports = Show(P)
    If Index(ports,'FLOWSTUDIO.1') >0 Then Say "1"
    Else Say "0"
  • »27.09.24 - 19:38
    Are you doing something in Hollywood?
    If you are, then you can do these things without using any external commands/programs:
    Function p_CheckProgram(exe$, port$)
    Local result = False
    If RunRexxScript("RETURN SHOW('P','" .. port$ .. "')", True) = "0"
    ; Launch the program if its port wasn't found.
    Run(exe$)
    ; Own WaitForPort implementation, you could also do Execute("WaitForPort", port$) instead.
    For Local i = 1 To 10
    If RunRexxScript("RETURN SHOW('P','" .. port$ .. "')", True) = "1"
    result = True
    Break
    EndIf
    Wait(50)
    Next
    Else
    ; Port was found.
    result = True
    EndIf
    Return(result)
    EndFunction
    If p_CheckProgram("SYS:Applications/FlowStudio/FlowStudio", "FLOWSTUDIO.1")
    RunRexxScript("ADDRESS FLOWSTUDIO.1;'OPEN FILE sys:MorphOS.readme LINE 10'", True)
    Else
    DebugPrint("Couldn't launch the program.")
    EndIf
  • »28.09.24 - 12:10
    Nadir
    Posts: 178 from 2003/3/17
    Unless you want to do something more complicated, there might be no need to go through the ARexx port at all. An easier alternative is to just call the program directly with the needed arguments. Unless you use the NEWAPP argument, the call will go to an existing FlowStudio session.
    By the way, FlowStudio already seems to have most of the functionality that you want to implement built into the app but itself. Still, maybe there are people who want a different/simpler app for this so don't let that dissuade you :-)
  • »30.09.24 - 10:55
    Papiosaur
    Thanks Nadir for your return ;-)
    I have create Easy2Makefile because i would like to port more games for MorphOS and this GUI will help me because often there is no Makefile to compile them. The GUI will create them easiest. Your feature to open a file at a specific line is very usefull when i compile and there are errors at line xx in the file yyyyy :-D
    Maybe one day i will create a new project from 0 with FlowStudio when i learn to developp in C/C++ :-D
  • »01.10.24 - 13:46
    Nadir
    Did you ever try creating makefiles from FlowStudio? In a simple case, you just need to add the needed files to your project through the GUI and press the hammer.
    FlowStudio maintains an xprj file with all information related to the project and then creates a makefile every time you want to build. You probably want to do something similar in your tool. In fact, there is also a small commandline tool that can create a makefile from an xprj. I don't remember if we include it in the SDK but if not, we could I guess.
    /Nicholai
  • »01.10.24 - 14:36
    Papiosaur
    No, i must try. But like i am not a developper in C/C++ i don't know all the features of FlowStudio to use it like an IDE to create and compile projects. For the moment i use it like a source file editor.
    Tcheko had realized a small tutoriel about that in the forum, i must search it and test it.
    Maybe it will be fine to add it (Tcheko tutorial) in the Guide of FlowStudio for the newbies.
  • »01.10.24 - 15:08
