Share a volume between MorphOS and a PC
    Posts: 3336 from 2003/3/5
    Use normal file sharing on Windows. It will be visible in Networks on MorphOS. You can then right click on a share and open its settings to make it auto-mount when MorphOS loads.
  • »19.09.24 - 20:39
    Papiosaur
    Posts: 2613 from 2003/4/10
    Thanks for your answers.
    Sorry, i'm novice in "network" domain....
    SMB 1.0 client activated.
    Must i create a "MorphOS user" or maybe add another "user" in MorphOS network prefs ?
    [EDIT] i see the shared partition on MorphOS but no files...
  • »20.09.24 - 10:26
    You should NOT activate SMB 1.0. That possibly breaks things. MorphOS supports SMB 2 and 3 just fine. 2 is your best option since it'll be faster than 3.
    Seeing no files likely means you're logged in as guest. Open the share settings on MorphOS and update your login credentials there. You'll have to re-mount the share afterwards.
  • »20.09.24 - 11:47
    Posts: 2220 from 2003/2/24
    Papiosaur wrote:
    @jPV: Maybe the tutorial should be updated?
    Did you do what's adviced with SmbFS and didn't read up to Smb2FS part? But yeah, maybe the more obsolete SmbFS part should be moved downwards or tell more clearly there's more up-to-date solution too.
    But I adviced you to watch the video about SMB2/3 support, and told you that other obsolete solutions can be found from the library :)
    [ Edited by jPV 20.09.2024 - 19:22 ]
  • »20.09.24 - 14:21
    beworld
    Posts: 683 from 2010/2/10
    Papiosaur a écrit :
    @jPV:
    oops, yes sorry i have just read the begining of the tutorial...
    lol
    My MOS ports
  • »20.09.24 - 17:11
