Howto change buffers for vfs: iso disks?
    igracki
    Posts: 460 from 2003/2/24
    If I double click on an iso file in ambient I can browse through it w/o extracting it before.
    But the buffers of this device are always set to 1 (use "AddBuffers @x:" to see how much buffers are set).
    I can change the buffers afterwards with AddBuffers command, but how can I set the initial default buffers?
    Btw, reducing the buffers with a negative number (f.e. AddBuffers @x: -100) doesn't seem to work!?
  • »02.04.24 - 17:51
    Posts: 891 from 2003/3/4
    It's likely that the virtual filesystem handler doesn't use dosbuffers but its own internal buffering system.
  • »02.04.24 - 18:07
