Mouse pointer in PNG format
    Posts: 2577 from 2003/2/24
    MOSSYS:Prefs/Pointers/Default
  • »24.03.24 - 17:03
    Piru
    Posts: 622 from 2003/2/24
    MOSSYS:Prefs/Pointers/<pointername>/Normal.info
    Note that the currently selected pointer types is specified in ENV:sys/mouse.conf (see Pointer="pointername"). "Default" is the OS default pointer if no prefs has been used to change it.
    Note that tooltypes HOTSPOTX and HOTSPOTY specify the hotspot offset of the pointer (default pointer has them at 0,0 but if you add support for other pointers the hotspot might not be exactly in the left top corner)
  • »24.03.24 - 17:11
