Posts: 1609 from 2012/11/9
Papiosaur -
Prt Scrn key is the key at the right hand side of the F12 key on a
WINDOWS keyboard, and AFAIK a Mac/Apple keyboard is NOT mapped to those same keyboard positioned keys.
I cannot remember the last time I used the
Grab Tool, as I usually use the
Screenshot (Screenbar module) or
SnapIt, which is my preferred screengrabbing utility, though SnapIt does have a few issues, not least of which is that you cannot grab an active video/GFX window or screen, as the VRAM handles the data and is inaccessible to the user as such for those purposes of taking sccreenshots! However, there does not seem to be a screngrab utility that can grab a video window, which is a real shame as it would be very handy on certain occasions.
Both
Screenshot and
SnapIt allow you to modify the keyboard shortcuts to hopefully better suit your requirements
