How to change fonts.
    matt3
    Posts: 776 from 2004/2/10
    I'm using a font that I downloaded from the web. I love the look of it, but it does not have the @ symbol in it.
    Is there a way to edit the font and add it?
    The font is finalfrontier.
  • »21.11.23 - 19:46
    Tcheko
    Posts: 540 from 2003/2/25
    Where do you want it to be used?
  • »21.11.23 - 21:23
    matt3
    I use it in Iris and PolyOrga and some area's of Ambient.
  • »22.11.23 - 04:11
    Templario
    Posts: 555 from 2012/4/28
    You can find other font here:
    https://www.1001freefonts.com/
    To edit free type fonts on MorphOS or Amiga there is a program you must to use a Linux and its FontForge for example, but some fonts have copyright and isn't possible change or add letters.
  • »22.11.23 - 06:42
    Tcheko
    Totally miss read initially. :)
    Ok. Just seeked for that font on dafont. There is also other symbols missing like underscore (_) or pipe (|). '{}<>' symbols are also totally wrong (star trek federation logos).
    This font is just good for doing graphic designs imo.
    Else, if you can find a copy of TypeSmith from SoftLogic and with some convertion tools, you might be able to edit it under MorphOS. Might be a serious journey. :)
    (There might be an archive of TypeSmith in AmigaFormat CD #03).
    [ Edited by Tcheko 22.11.2023 - 09:06 ]
  • »22.11.23 - 07:04
