Force change view of an Ambient window in command line
    Papiosaur
    Posts: 2607 from 2003/4/10
    Hello,
    For Easy2Install, i use "open" command to open a drawer in an Ambient window.
    I would like to change (force) view mode : list view (all files) for shell commands or icon mode (all files) to show icons (sometimes drawers containing icons don't have icon...)
    Is it possible to force view mode (by lister, by icon view mode) in command line with Arexx or LUA or maybe news options for "open" command in a future version of MorphOS?
    Thanks for your answer.
  • »06.10.23 - 13:10
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    Look at sys:MorphOS/Ambient/arexx/showam.rexx
  • »06.10.23 - 13:38
    Papiosaur
    Cool! i think it could help me ;-)
    Thanks a lot!
    I will try to understand the script now :-D
    [EDIT] Work perfectly ;-)
    Maybe i could adapt this AREXX script to Hollywood or LUA langage with arguments to have only one script?
  • »06.10.23 - 14:04
    Posts: 2217 from 2003/2/24
    I'm in a hurry now, but made quickly couple examples how you could convert the script into Hollywood. Not sure if I got everything right, but I'll check after couple days ;)
    ; This function uses Hollywood's ARexx support functions, but requires 68k rexxsyslib.library installed
    Function p_OpenAmbientARexx(location$, view$, mode$, left, top, width, height)
    Local params$ = "?view=" .. view$ .. "&mode=" .. mode$ .. "&top=" .. top .. "&left=" .. left .. "&width=" .. width .. "&height=" .. height
    Local rexx$ = "ADDRESS AMBIENT;'LoadURI \"file://" .. location$ .. params$ .. "\" newwin'"
    RunRexxScript(rexx$, True)
    EndFunction
    ; This function uses the RXCmd shell command and works out of the box on MorphOS, but doesn't work on other operating systems
    Function p_OpenAmbientShell(location$, view$, mode$, left, top, width, height)
    Local args$ = "AMBIENT \"LoadURI *\"file://" .. location$ .. params$ .. "*\" newwin\""
    Execute("MOSSYS:C/RXCmd", args$)
    EndFunction
    ; Example 1
    p_OpenAmbientARexx("Ram Disk:", "list", "thumbs", 50, 50, 440, 320)
    ; Example 2
    p_OpenAmbientShell("Ram Disk:", "list", "thumbs", 600, 50, 440, 320)
  • »07.10.23 - 03:26
