Problem with Sys:Data/ drawer
    Papiosaur
    Posts: 2615 from 2003/4/10
    Hello,
    i have a little problem to install MouseTracker commoditie.
    The installer script do an error when he wants copy files to Sys:Data/ drawer.
    Unfortunaly, the drawer Sys:Data/ is not created by the installer script if not exists.
    I ask me if this drawer was not created at the installation of MorphOS in previous versions.
    Any ideas please ?
    Thanks
  • »04.10.23 - 06:34
    Posts: 3336 from 2003/3/5
    MorphOS does not create SYS:Data.
  • »04.10.23 - 12:19
    Posts: 2220 from 2003/2/24
    Some bundled software in MorphOS do create it though, so I guess it's not harmful to create it, or check its existence, yourself either.
  • »04.10.23 - 12:25
    BTW. I tried MouseTracker just out of curiosity, but it seems to be a buggy program. First it made my Clock screenbar texts disappear and then there's a hits galore in the debug log when trying open settings or statistics. Not recommended to install in its current state :)
  • »04.10.23 - 12:50
    Papiosaur
    Thanks jacadcaps for the info!
    Yes, that’s what I’m going to do, thanks
    Thanks for the info too, i will contact the author.
  • »04.10.23 - 18:31
