Updating to 3.18 from USB keeps failing
    Travis_H
    Posts: 166 from 2009/12/17
    I followed the instructions thoroughly, tried two different USB sticks and still only get as far as the screenshot shows.
    I'd had successfully updated two machines to 3.17 with USB (using the same stick) previously.
    https://photos.app.goo.gl/4diTUGYDABDZjPmL9
  • »26.07.23 - 19:39
    tolkien
    Posts: 585 from 2013/5/29
    I have installed morphOS 3.18 from usb in my three machines without problems.
  • »27.07.23 - 15:03
    Posts: 2220 from 2003/2/24
    It seems that boot.img has been loaded successfully, but it fails to load morphos.iso. Are you sure the iso file is named like that on the stick?
  • »27.07.23 - 15:19
    Posts: 903 from 2003/3/4
    Get a checksum check on the ISO, make sure it wasn't corrupted on download.
    You may think that impossible, but I spent three weeks in July trying to install Linux from an ISO only for it not to boot - only to find the ISO, downloaded on a Windows machine - was corrupt.
  • »27.07.23 - 17:32
    Travis_H
    I will do this next. I had forgotten to rename morphos-3.18.iso to just morphos.iso, but that was the cause of only the first couple fails!
    I'll download the file and try again soon.
  • »27.07.23 - 18:46
    bigfoot
    Posts: 510 from 2003/4/11
    Also do make sure you copied the right boot.img file for your computer. I know you said that you followed the instructions thoroughly, but it's easy to accidentally copy the wrong file, and doing so could also result in a situation like the one you end up in.
  • »28.07.23 - 02:20
    Travis_H
    Yes, this turned out to be the problem! I had simply copied the boot.img from the root directory of the iso. Digging around, I saw the mac32 version, so I gave it a try. Bingo!
    Thanks for the tip.
    TJH
  • »29.07.23 - 13:40
