OpenURL problem
    Posts: 3336 from 2003/3/5
    You should have no real need to edit things by hand. If you don't have Iris already configured, just add a new entry and select Iris from the popup menu and save settings.
  • »06.06.23 - 11:59
    Papiosaur
    Posts: 2615 from 2003/4/10
    ok but bizarre options via menu as subject, body, etc are not inserted directly after WRITE "%a"
    i have tried this url:
    mailto:mail@mail.fr?subject=nameofthesubject
    but ?subject= option seems not reconized
    Any idea please ?
    [ Edité par Papiosaur 06.06.2023 - 16:30 ]
  • »06.06.23 - 12:29
    Iris doesn't support 'subject'.
  • »06.06.23 - 12:38
    I'll see if this can be added in the next release.
  • »06.06.23 - 12:53
