iGame
    bash64
    Posts: 977 from 2010/10/28
    anyone gotten iGame to work in morph?
    I keep getting messed up drop down menus.
    Installed the two mui classes and libraries (under the morphos folder).
    did the best i could finding those libraries...render and guigfx.
    it runs fine.
    just cant use the drop down menu to edit repos or scan
  • »10.05.23 - 10:16
    Posts: 848 from 2007/10/23
    "Now iGame doesn't fail to start even if any of the guigfx.library, render.library or Guigfx.mcc is missing. It falls back using the datatypes and the "No GuiGfx" checkbox is blocked in the settings"
    At least there are some open issues.
  • »10.05.23 - 10:35
    bash64
    yeah, i saw that on github
    i can come back to this. its not t6he end of the world.
    my g4 laptop went south years ago and i moved on to other hobbies
    i just got another one and am testing to see if everything still works on amiga
    so far so good.
    planning on registering soon
    fun for the whole amiga club
  • »10.05.23 - 10:49
    bash64
    i got an a500 rpi project almost done.
    bought the scourge of the underkind bundle, an a500 keyboard and adapters
  • »10.05.23 - 10:50
