Problem to launch a script in WBStartup
    Papiosaur
    Posts: 2614 from 2003/4/10
    Hello all,
    i have an AmigaDOS script in WBStartup with an icon and script option activated.
    When i double click, the script is executed, when i start MorphOS, nothing append...
    Any idea please ?
    [ Edité par Papiosaur 28.06.2022 - 18:11 ]
  • »28.06.22 - 14:07
    Posts: 478 from 2019/5/9
    Try to set icon type as "Project" and add Default tool "c:iconx". It normally works from Ambient, try if it works also from WBstartup.
    Or, simply add your sript to s:user-startup. It will work for sure, but I know this is not the exact you want.
  • »28.06.22 - 14:29
    Papiosaur
    Thanks sailor for the tips.
    ok bizarre now it work with the two possibilities...
    i have added a "wait 5" before the wget command to have internet conection activated.
    [EDIT] is it possible to remove output window please ?
    [ Edité par Papiosaur 28.06.2022 - 20:00 ]
  • »28.06.22 - 15:57
    Posts: 3336 from 2003/3/5
    There's no guarantee that a 'wait 5' will ensure that networking is up. You should run a script that needs wget from user-network-startup.
    Redirect the output to >NIL: and it should not pop up
  • »28.06.22 - 16:43
    Posts: 2220 from 2003/2/24
    I don't know which would be the best way to test it (does Netstack have some ARexx command to tell the state, for example?), but I think a pretty safe way is to check if inetd is running. It's launched as the last thing before user-network-startup is launched.
    So add something like this in your script:
    WaitForPort INTERVAL=5 inetd.ipc
    If NOT WARN
    ; Do your stuff here
    EndIf
  • »29.06.22 - 05:38
