Registration failed
    Travis_H
    Posts: 166 from 2009/12/17
    iBook G4 upgraded to 3.16 and tried to register, but the regtool always fails. Double-checked I'm online and browser is working.
  • »16.04.22 - 11:05
    Posts: 3336 from 2003/3/5
    Could you share the error you are seeing?
    Also, are you sure your system date is set correctly? HTTPS connections will fail if your system time is in the 1980s :)
    [ Edited by jacadcaps 19.04.2022 - 15:22 ]
  • »19.04.22 - 10:02
    Travis_H
    Bingo! Since I only had 30 minutes at a time, I usually skipped setting the clock!
    Registration paid.
    TJH
  • »19.04.22 - 18:35
    Posts: 848 from 2007/10/23
    Maybe NetStack should show a warning.
  • »19.04.22 - 20:37
