USB and SD cards sizes
    Templario
    Posts: 556 from 2012/4/28
    In the market there are USB and SD cards of 8GB, 16GB, 32GB, 64GB, 128GB, MorphOS cans read and write in these GB sizes, it has support for this big units? And speeds, because there are speciald SD cards for photocameras, neither it gives problem with MorphOS?
    Thank you for your suggestions.
  • »30.11.21 - 17:04
    Posts: 1385 from 2010/1/6
    Not a thing of MorphOS. Depends on filesystem on these cards (FAT, NTFS,....), whether they allow such sizes.......
  • »30.11.21 - 17:11
    Posts: 2217 from 2003/2/24
    The size shouldn't be a problem, because much bigger HDs also do work, so these relatively small SD cards shouldn't be an issue. I don't think it matters much what the actual device is physically if it still acts as a standard drive for the system...
  • »01.12.21 - 12:02
