Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
General Discussion
Tools and utilities ?
Papiosaur
# 1
Posts: 2615 from 2003/4/10
Hello,
in MorphOS, there is tools and utilities drawer.
Maybe it will be better for the user to create hdtools for hdtools and utilities for the others soft...
papio-software.com
www.meta-morphos.org
www.morphos-storage.net
24.11.21
13:35
ASiegel
# 2
Posts: 1397 from 2003/2/15
I believe the rationale behind the naming scheme is that "tools" are applications that can potentially harm your computer or at least break functionality, thus should be used with extra care, whereas "utilities" are not.
24.11.21
14:12
Papiosaur
# 3
Hammer instead tools so
Thanks ASiegel for precisions
papio-software.com
24.11.21
15:04
