New on MorphOS-Storage
    Papiosaur
    Posts: 2581 from 2003/4/10
    Hello everyone,
    I am pleased to announce something new on MorphOS-Storage and soon on Amiga-Storage as well.
    You may have noticed, there is a new green icon that has appeared.
    This is a link to a script to download, unarchive and launch the program.
    To make it operational, you just have to create in Odyssey a mimetype for the text/install files and therefore the extension "install" with as "external" viewer "sys:morphos/c/execute" and choose %f on the right for "generated local path"
    Then click on the green icon corresponding to what you want to install.
    There is still a lot of script to do ...
    [ Edité par Papiosaur 24.10.2021 - 20:41 ]
  • »21.10.21 - 09:40
    Posts: 2217 from 2003/2/24
    Couple quick notes:
    1) Tried with Feedback 11 installer: installer points to a .zip file, which doesn't work. It should be pointing to .lha file
    2) This line produces an extra quotation mark at the end of the output line:
    echo "Feedback 11 has just been installed to$dest
    I would replace it with this for a cleaner solution:
    echo "Feedback 11 has just been installed to " noline
    echo $dest
    3) These lines won't work, because if you click No in the requester it gives you 0, not 2.
    if $start eq "2"
    if $install eq "2"
    So do this if you want it to close the window with No:
    if $start eq "0"
    if $install eq "0"
    4) You could also be using Else there.. maybe it would be more elegant :) Like this:
      if $start eq "1"
    cd $dest
    open void-FB11/
    run void-FB11/void-fb11.exe
    else
    endcli
    endif
    Unless you plan to add more options there later...
  • »21.10.21 - 15:14
    Papiosaur
    Problem resolved ;-)
    If some guys would like help me to add some scripts, you are welcome :-D
    The model is similar for all archives, you can take model as this script:
    https://www.morphos-storage.net/misc/qrcodelab_0.8.install
    You must change paths and names.
    You can send me your script(s) to papiosaur2 à hotmail.fr
    The name of the script must be similar of the archive name and add .install.
    Thanks for your help ;-)
    [ Edité par Papiosaur 23.10.2021 - 12:27 ]
  • »22.10.21 - 18:01
