Powerbook won't boot past Quark
    Intuition
    Posts: 1116 from 2013/5/24
    Just tried to boot my PB (A1138 IIRC) for the first time in about three years or so.
    It just boots to a blank screen with an "Ambient Screen"title bar and a mouse cursor that moves.
    Same happens even if I boot with no startup-sequence from the early boot menu.
    Can anyone suggest anything that might help please?
  • »05.04.21 - 13:08
    Posts: 3336 from 2003/3/5
    Did you try booting from USB?
  • »05.04.21 - 13:13
    NewSense
    Posts: 1618 from 2012/11/9
    @ Intuition - or tried booting from the MorphOS installation CD? Maybe the HDD files have got corrupted over that period of time/HDD failing in some way/not retained all the data intact to boot correctly.
  • »05.04.21 - 13:47
    Intuition
    Thanks guys. I just installed 3.15 over the top of 3.10 from DVD and it works fine now.
    Could it be due to the clock battery totally dying? I had to set the correct time in the installer.
  • »05.04.21 - 13:57
    Posts: 1390 from 2010/1/6
    My experience is, that such things happens, if there are some old prefs-files (MUI, etc.) from a pre-installation left. This can cause the strangest things........ (Poseidon.prefs are often such a problem during booting - system hangs after quark has booted...)
  • »05.04.21 - 14:56
    Intuition
    Scribble seems to have been deleted from my installation after I upgraded and installed the latest SDK any way to get it back?
    I had a nightmare getting connected to any of the three WiFi networks in my house. Finally got one working by giving static IP, setting the router IP as the gateway and using opendns.
    @jaca
    Wayfarer is awesome! Amazing work you've done on it so far, thank you!
  • »05.04.21 - 16:35
    Posts: 848 from 2007/10/23
    Scribble (now FlowStudio) is not longer part of the SDK.
  • »05.04.21 - 17:20
    Intuition
    Thanks. I actually already had an icon for FlowStudio on my panel, just totally forgot it existed lol
    It doesn't work though for some reason. I'll have a look at the log the crash generates tonight hopefully.
  • »07.04.21 - 06:34
