ARexx issue
    wicknix
    Posts: 18 from 2020/12/1
    Anybody know why i get this popup box? mH8Fntc
    Back story... I made a back up of my G4 mini and copied it's contents to my G5 so i wouldn't have to set everything up again. Everything else works flawlessly, except a few things like the youtube extractor.
    Cheers
  • »24.12.20 - 05:10
    wicknix
    Thanks. I already have the rexxsyslib.library installed, so i guess i'll try tips and tricks method next time i boot in to MOS. Has to be something simple i missed. This doesn't happen on my mini.
    Cheers
  • »24.12.20 - 05:46
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    This happened when I copied my old hard drive to a new SSD.
    [ Edited by IKE 11.04.2022 - 13:44 ]
    IKE
  • »11.04.22 - 17:42
    Piru
    Posts: 622 from 2003/2/24
    Copying files over won't rename the rexxsyslib.library in mossys:libs
  • »11.04.22 - 18:47
  • IKE
    IKE
    I used the "repair" option in Grunch and that did the trick!
    IKE
  • »12.04.22 - 00:02
