SMBFS or SMBFS ?
    Posts: 1385 from 2010/1/6
    I've tested V2.22. Runs MOS2MOS or MOS2Amiga, but got then problems with connections to WinTel-Comps (even XP). Switched back to V50.3 (2005)....Try it for yourself - you need only to copy smbfs_2.22 to your Samba/bin installation. You may use smbfs or smbfs.020.
  • »08.01.20 - 17:12
    Posts: 2217 from 2003/2/24
    The built-in SMBFS in MorphOS has been working very reliable and fast in my use (I do big file transfers and watch movies over it etc, with both Win10 and Linux mounts), and the MorphOS team has been updating/fixing it occasionally, so unless someone tells a good reason to use other branches, I would stay with the built-in version.
  • »09.01.20 - 04:19
    For smbfs 2.22 see here: https://www.a1k.org/forum/index.php?threads/65311/page-38
  • »09.01.20 - 11:56
