Just simple question
    droopy
    Posts: 35 from 2013/12/12
    What is the correct directory to put the keyfile.
    I reformat and installed the latest pub lic version and need to re submit my keyfile (I have is saved)
  • »06.08.16 - 11:07
    Posts: 1099 from 2004/9/23
    SYS:Devs/MorphOS.key
  • »06.08.16 - 11:15
    droopy
    Nice.. now it works again..Thanks
  • »06.08.16 - 11:24
    I was pretty sure that this was the correct location (or anywhere else in the default "Path" for MorphOS SYS:", but looked all over the official MorphOS website for the answer, and couldn't find it. Then I searched the MorphOS Library here on MorphZone, and the search results for "morphos.key" came up empty.
    I'm sure that clear instructions are included in the email that the keyfile is sent inside, but it would also be a good idea to include instructions on where to put the keyfile, for people who need to re-install MorphOS from scratch years later, and can't find the original email message, but have a copy of the keyfile on some backup device. Just a suggestion for an additional line in the MorphOS installation instructions on the official website.
    [ Edited by amigadave 07.10.2019 - 17:29 ]
  • »07.10.19 - 22:27
  • ASiegel
    Posts: 1397 from 2003/2/15
    @ amigadave
    It's been added to the "Help Desk" section of the MorphOS website.
  • »08.10.19 - 04:41
