MorphOS 3.12 will not boot on my Pegasos I
    Posts: 23 from 2018/4/20
    I have 3 x Pegasos I with Ati radeon 7000 .
    I typ on Frimware .
    boot /pci/ide/disk@0,0:0 bootpeg1.img bi TEST:morphos-3-12.iso
    the cursor do xxxxx
    and stop by _
    Can somebody run morphos 3.12 on Pegasos I ?
    [ Bewerkt door Olystany 06.10.2019 - 21:30 ]
  • »06.10.19 - 18:02
    Posts: 3336 from 2003/3/5
    test: sounds pretty much like a volume name. This will not boot. You need to use a partition name there, like DH0, HD1, etc.
  • »06.10.19 - 18:15
    test: are my Partitionname of de partition i try TEST: ,
    its works always , not at MorphOS 3.12 .
    [ Bewerkt door Olystany 06.10.2019 - 21:27 ]
  • »06.10.19 - 18:26
    Posts: 903 from 2003/3/4
    I don't think you can boot from iso files or SFS partitions on Peg-1 openfirmware.
  • »06.10.19 - 18:56
    You can as long as the boot.img is loaded OK.
  • »06.10.19 - 18:57
