Maximal Storage space supported
    Posts: 37 from 2018/10/18
    Hey,
    is there still a limitation of 128 GB for one Hard Drive ?
    Or can i use an SSD with 256 GB
  • »27.10.18 - 13:06
    Posts: 2580 from 2003/2/24
    Limitations will apply based on the filesystem used (aka no partition >128GB) but the drive can be as big as you like.
  • »27.10.18 - 13:34
    That is what i mean.
    Are there any changes in working progress ?
  • »27.10.18 - 14:19
  • ASiegel
    Posts: 1397 from 2003/2/15
    @sojuniter
    You can certainly use bigger partition sizes as long as you pick the appropriate file system.
    Here is an overview: MorphOS file systems and partition sizes
    Legacy file systems are unlikely to ever see support for larger partition sizes as this might break compatibility.
  • »27.10.18 - 15:57
    Posts: 2220 from 2003/2/24
    There has never been 128 GB limit for a _hard drive_, the limit is per partition with SFS. So, it's always been perfectly fine to make, for example, two 128 GB SFS partitions on a 256 GB drive. Or more with bigger drives, or it's fine to leave some space unused too if you like.
  • »28.10.18 - 07:15
    Posts: 903 from 2003/3/4
    My advice would be just to bite the bullet and go for two SFS partitions.
    Although a full size FFS partition on an SSD would also be tempting. Revalidation is an extreme pain on modern-sized hard drives, but it should be really quick on SSD. Just keep in mind that disk recovery tools wouldn't work on it...
    Edit: assuming the link that Andreas posted is right about FFS2. Has anyone ever tried huge partitions on it?
    [ Edited by KennyR 29.10.2018 - 12:58 ]
  • »29.10.18 - 11:46
