Amiga Racer asks me the powersdl.library v15
    Templario
    Posts: 561 from 2012/4/28
    I have this current problem with the game running on MorphOS, it asks me the powersdl.library v15 when I have installed the v16.1, it is one bug in the game and where I can find the v15?
  • »19.11.17 - 08:54
    Henes
    Posts: 507 from 2003/6/14
    The message does not mean the game is asking for powersdl.library v15 specifically.
    It means it is asking for any version equal or superior to v15. So a v16 must work.
    There could be various reasons for your issue:
    1) You have several versions installed and something is opening the v15 first.
    You should make sure you have only one version in sys:libs/ and nowhere else (f.e. in some game's own libs/ directory).
    You can use Ambient's built-in search functionality to find all your powersdl.library copies...
    2) v16 requires some other library missing on your system. Snoopium (if correctly configured) will help you in this case.
    3) more...
    And the same for all powersdl's sub libraries (powersdl_image, powersdl_mixer etc...)
  • »19.11.17 - 10:15
    igracki
    Posts: 471 from 2003/2/24
    I have v16.1 and AmigaRacer starts/run without a problem!
    These powersdl libraries are needed/opened by AmigaRacer:
    powersdl.library v16.1
    powersdl_mixer.library v8.9
    powersdl_net.library v8.2
    powersdl_ttf.library v8.1
  • »19.11.17 - 11:56
    defender
    Posts: 249 from 2011/4/24
    After updating to 3.98 i got this message:
    Warning: Not enough free sectors (0) to place 50 objects.
    But only in swisserland!
    Everythings else (what I have tested now) works fine.
  • »19.11.17 - 15:49
    Templario
    Thank you.
    I installed the Barkanoid demo and it installed several libraries, may7be the installer script corrupt some library, but I reinstalled the v16.1 even to copy them from my macmini.
  • »19.11.17 - 17:22
    Templario
    I have these library versions too. The problem has in other way.
  • »19.11.17 - 17:25
    igracki
    Here too!
    I tried the ARCS feature and selected Swisserland and pressed "Build Track" then the message appeared in a shell window:
    Warning: Not enough free sectors (0) to place 10 objects.
  • »19.11.17 - 17:53
    Templario
    Maybe the game needs a new update for the executable.
  • »20.11.17 - 09:22
    Templario
    Solved, I reinstalles MorphOS and now the game works, only for MorphOS v3.10 I hope that it will have a better core for PowerBook G4 because the current 3.9 gives much problems.
  • »03.12.17 - 12:14
    Posts: 919 from 2004/1/24
    Funny, 3.9 works like a charm on my Powerbook, no issues whatshowever.
  • »03.12.17 - 19:11
    Templario
    I have your good luck with my MacMini, because with my PowerBook sometime I have problems with the visual enviroment other times with OWB with it has enable the javascript and OWB crash because also crash the MorphOS.
  • »05.12.17 - 12:36
