Tip of the day - how do I set default language?
    Posts: 3 from 2017/11/18
    How do I set the Tip of the Day default language = English (US)?
    All of the tips are currently in French.
    Meanwhile, all other locale settings reflect English (US) except Tip of the Day.
    Thanks,
  • »18.11.17 - 22:20
    Posts: 848 from 2007/10/23
    Strange, the catalog should point to the correct file.
    You find the tip files in MOSSYS:Data/Tips/.
    [ Editiert durch polluks 19.11.2017 - 02:20 ]
  • »19.11.17 - 00:12
    Posts: 2220 from 2003/2/24
    Do you have Chrysalis pack installed? Maybe it has copied French only database there? Or maybe check the icon tooltypes if they point to some French file?
  • »19.11.17 - 08:15
    Hey, polluks and jPV. I'll look into the tips file. And yes, I did install the Chrysalis pack. I'll check the icon tooltypes. Thanks for the *your* tips. ;-)
  • »20.11.17 - 09:25
