WPA2 security hole
    Posts: 2095 from 2003/6/4
    www.krackattacks.com
    Probably MorphOS is also affected.
  • »17.10.17 - 04:27
    Posts: 12569 from 2003/5/22
    Indeed, as it uses wpa_supplicant.
    From your link:
    "Our attack is especially catastrophic against version 2.4 and above of wpa_supplicant [...]. Here, the client will install an all-zero encryption key instead of reinstalling the real key. [...] This makes it trivial to intercept and manipulate traffic sent by these [...] devices."
    I don't know which version of wpa_supplicant is used in MorphOS 3.9, though.
  • »17.10.17 - 07:12
    Posts: 611 from 2003/4/11
    wpa_supplicant 2.4 has been released in March 2015 and the code which WirelessManager is based on hasn't changed much since its original release in 2013, so feel free to do the math ... :)
    If there is anything we can do/need to do about the issue, we will most likely include it in a future update.
  • »17.10.17 - 08:06
    Posts: 1362 from 2004/2/8
    Darn, even more delays...
  • »17.10.17 - 09:11
    Posts: 903 from 2003/3/4
    Chances are you're using a hardware router, and one where you're not going to get a firmware update, so you'll still be vulnerable even after MOS is patched.
    Who'd have thought Laire's advice to 'buy a router' would have backfired after all this time? ;)
  • »17.10.17 - 18:41
    Yes, a WiFi one at that, else WPA2 wouldn‘t be needed, would it?
    MorphOS users can easily buy a new router, but can they stop using MorphOS and keep being MorphOS users?
    He never said it would have to be a wireless one ;-)
  • »17.10.17 - 20:10
    Why - isn't it possible to use a computer directly connected to a modem as your router and use WPA2 to connect to that?
  • »17.10.17 - 21:59
    You're right, it is. I misread your post
  • »18.10.17 - 06:46
    Tom4hawk
    Posts: 4 from 2016/10/2
    No, it's mostly a WiFi client problem:
    https://www.krackattacks.com/#faq
    Relevant question:
    "What if there are no security updates for my router?"
    Answer:
    Our main attack is against the 4-way handshake, and does not exploit access points, but instead targets clients. So it might be that your router does not require security updates. We strongly advise you to contact your vendor for more details. In general though, you can try to mitigate attacks against routers and access points by disabling client functionality (which is for example used in repeater modes) and disabling 802.11r (fast roaming). For ordinary home users, your priority should be updating clients such as laptops and smartphones.
    PowerBook5.5 G4 1500MHz|1.5GB DDR2|Radeon 9700 64MB|80GB Spinning Rust|MorphOS 3.9
  • »18.10.17 - 11:41
    TheMagicM
    Posts: 1220 from 2003/6/17
    if your ap is running as a client in bridge mode, yes it is affected.
  • »19.10.17 - 14:31
