MorphOS filesystems
    Posts: 2220 from 2003/2/24
    I once started to create a library page about MorphOS native filesystems, but I haven't felt that it'd be complete and correct enough to be released publically. But as I seem to be in the dead end myself, I would need some help with it... or at least I'll give it to public as rough guidelines at least :)
    So, here it is: File Systems.
    Any discussion and corrections for the page are welcome to this thread.
  • »07.09.17 - 12:27
    Posts: 1390 from 2010/1/6
    You've forgot ENVOY-Filesystem at NET-filesystems......
  • »07.09.17 - 12:36
    Is there a MorphOS native version of it somewhere? I decided to start with native software only... adding all 68k options would make too much work for now :)
    [ Edited by jPV 07.09.2017 - 19:33 ]
  • »07.09.17 - 14:32
    You're right- is only a 68K-version (but works good)......
  • »07.09.17 - 15:35
    Posts: 12569 from 2003/5/22
    Excellent. Thanks.
    IceFS may also be bootable on Sam460, I think.
  • »07.09.17 - 16:48
    TheMagicM
    Posts: 1220 from 2003/6/17
    Very well written. Thanks!
  • »08.09.17 - 11:00
    Posts: 848 from 2007/10/23
    Missing are FTPMount and FS1541.
    Better write
    Built-in = MOSSYS:L
    3rd party = L:
  • »08.09.17 - 13:46
    Added, as well as Amiga Cloud Handlers.
    Better write
    Built-in = MOSSYS:L
    3rd party = L:
    Well... I meant the location is where they work from or where they can be found when you start looking for one... but OK, I changed the generic L: to more exact MOSSYS:L, but maybe I won't put L: for 3rd party, because they aren't found there before user himself downloads and installs them :)
  • »08.09.17 - 14:37
    1541 spec:
    16, 164K, 170K
  • »08.09.17 - 15:53
