Where do you prefer save preference files?
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    I have simple question (kind of poll) to MorphOS users. The question is:
    Where do you prefer save preference file of an application?
      1. PROGDIR:settings
      2. ENV: and ENVARC:
      3. SYS:Prefs/Applications
    In my opinion the first case is not good solution. The second case is classic AmigaOS solution. The third place is new MorphOS standard. This directory contains preference files of e.g.: Jukebox, MagicBeacon, Shuffle.
  • »12.06.17 - 16:56
    Posts: 1099 from 2004/9/23
    Well, basically it depends on why kind of application you create.
    If you have a commodity the user may drag around storing config inside the icon may be even better.
    Progdir: only works if you have one. If there is just the application + icon there is no way to store data in progdir:.
    Sys:Data/<appname>/... is a good and unify way to store data and config, too. When using MUI it is probably a good idea to use its config feature and store data using muis data space feature.
    Probably it is the best to store data in sys:data/<appname> and config in sys:prefs/<appname> if mui setings do not work for the case.
  • »12.06.17 - 17:44
  • MDW
    MDW
    Good answer. :) Where would you save preferences of demoscene production (demo)?
  • »13.06.17 - 03:20
    Posts: 2581 from 2003/2/24
    NIL:
    *runs*
    For something like this I'd prefer either the icon (tooltypes) or progdir: so you can delete the whole thing after watching it twice.
  • »13.06.17 - 07:02
  • MDW
    MDW
    Kronos wrote:
    NIL:
    *runs*
    It is interesting point of view. Thank you.
    Generally I don’t like preferences in PROGDIR because during updating application to new version I have to remember keep settings. If preferences are in ENV/ENVARC or SYS:Prefs/Applications/<AppName> I can just delete all files in application folder and install new.
    However in case of demoscene productions I can accept your solution. :) I don’t like a lot of preference files in ENVARC (and especially ENV in RAM) saved by applications which I use once or twice. :)
    This is not easy issue. Maybe in future MorphOS Team should add something like AppCleaner for macOS which removes application with all its preferences and data outside the application folder. It is very simple solution but works very well…
  • »13.06.17 - 10:21
    Posts: 848 from 2007/10/23
    Maybe you simply uninstall for example by Grunch :-)
  • »13.06.17 - 10:39
  • MDW
    MDW
    I like Grunch (especially for updates)! However I don't remember if the Grunch deletes preference files when I delete an application.
  • »13.06.17 - 10:42
    Crumb
    Posts: 738 from 2003/2/24
      1. PROGDIR:settings
      2. ENV: and ENVARC:
    1. Tooltypes or config files are ok
    2&3 it's not ok because it pollutes my system with files without my consent. Each app can do unexpected things and scatter files all over my hd. It's easier for me to do a backup with lha of the contents of a directory than looking for each individual file at envarc/prefs/whatever.
    Tooltypes are a good idea for a demo.
    An app should be unpacked to a directory and that's all. No installers, no package managers. Grunch is nice but I prefer to keep backups of my lhas... If author dissapears and repository dies no backups Will be available. Aminet IS prefered: mirrors worldwide and enough visible. Checking out each author webpage is a pain in the ass. Grunch installing stuff located at aminet servers os nice... Personal servers aren't good in the long term... See itix server for example.
    [ Edited by Crumb 13.06.2017 - 16:56 ]
  • »13.06.17 - 12:45
  • MDW
    MDW
    Yes, you are right but settings should be kept after update application. I also don't like when an application saves files outside its directory. However I accept if application saves prefs in directory for preferences (ENV/ENVARC, SYS:Prefs/Applications/<AppName>). It is consistent with rules of operating system.
  • »13.06.17 - 13:02
  • MDW
    MDW
    Thank you for the discussion. Generally Amiga-people don't like if an application saves something outside its directory. So I will save preference file in PROGDIR. In case of demoscene productions it is acceptable for me. :)
    I hope nobody starts demos from CD/DVD. ;) ;)
    [ Edited by MDW 13.06.2017 - 17:09 ]
  • »13.06.17 - 13:08
    connor
    Posts: 650 from 2007/7/29
    You should always consider that not everybody uses Grunch, so you must think of the plain way to install/update your demo in any case. And what is the problem to exclude one file from delete “~(myconfigfile)”? Or why do you have to delete existing files at all when you install an update? If you delete everything and then copy everything then this is not really an “update”. In that case you can tell the user “throw away the old directory and unpack the new one”. Not what I expect from an update btw. And wouldn’t your demo need a nice icon? So why not store all settings in its tooltypes? If the programmer thinks well, then there is no need for things like AppCleaner, CCleaner and all that stuff.
  • »13.06.17 - 13:57
  • MDW
    MDW
    In my opinion tooltypes in icon is solution for small programs which don’t have GUI for settings.
    Each operating system specifies folder outside the application folder where preferences and application data are stored. Amiga-users (me too) don’t like ENV because it occupies RAM. :) I am happy that MorphOS team tries to force new standard (SYS:Prefs/Applications/<AppName>). In my opinion ENV/ENVARC should be used only for common preference which are used by more applications (e.g. MUI, global environment variables).
    Generally is not good if application modifies its folder. Application on iOS and macOS (only apps installed from MacAppStore) today can't do it.
    All additional data (like plugins, extensions) shouldn't be installed in application folder. After delete application (or "reinstall"), user settings and data should be kept and user should know where it is stored.
    In MorphOS we add libraries to SYS:Libs. MOSSYS:Libs shouldn't be modified. It is very good solution - now update of MorphOS is easy and non-problematic. Try to update AmigaOS 3.x... It is impossible without big user intervention. :) :)
  • »13.06.17 - 15:18
    Posts: 2220 from 2003/2/24
    If the database item is written correctly by the rules, it will also remove the preference files. I've been using ENV/ENVARC for my programs, and if you uninstall them with Grunch, these will be cleared too.
  • »13.06.17 - 18:11
  • MDW
    MDW
    I didn't know. Great!
  • »15.06.17 - 12:57
    Posts: 1521 from 2003/2/24
    ENV/ENVARC has one advantage: it supports Use/Save pattern out of the box. That is, if you want/need this particular preferences model.
  • »15.06.17 - 18:03
    r-tea
    Posts: 317 from 2005/3/27
    Keep in mind, we DO NOT have folders at all. We do have directories or (better) drawers.
    :-D
  • »15.06.17 - 18:52
    Minuous
    Posts: 166 from 2010/2/12
    The official User Interface Style Guide (http://amigan.1emu.net/aw/style.zip) already gives lengthy guidance to developers on this matter.
  • »16.06.17 - 06:17
  • MDW
    MDW
    I am not sure if we need the Use/Save model in 2017. :) However if we need, it is very easy way for support this model.
  • »16.06.17 - 18:12
  • MDW
    MDW
    :-D
    You are right! I am lame! It is result of use other operating systems... :(
  • »16.06.17 - 18:14
  • MDW
    MDW
    Thank you for the documentation. I didn't know the official user interface style guide specifies reading app name.prefs from PROGDIR: before ENV:. It is good solution! I will implement my preferences according the specification. Thanks!
  • »16.06.17 - 18:28
    Of course we need, I would really hate to give up with it! I just hate the automatic saving trend on other platforms. If I play around with settings to try different things, it's hard to revert them back to original well-working ones. Who can remember all changes they have been making while playing around? And if you temporarily need some different settings, Use is just good for it. Again, no need to trying to memorize how they were before you made your temporary changes, and you just don't need to go tune them again in the next session, because they're already back to saved ones after a boot. This model is one of the best inventions on Amiga and I want to keep it.
  • »17.06.17 - 04:18
