PowerMac G5 Install...Works GREAT!
    SteveE617
    Posts: 80 from 2013/1/26
    Installed 3.2 on my PowerMac G5, 2.0 Dual Processor, 2GB Ram, 1TB HD with Radeon 9800XT. No installation hiccups!
    Pack Chrysalis 3.1.3 no longer installs from the "Install" icon. No big deal at this point. Just excited to put these G5s to work!
    Thank You to the entire Dev Team! Well Done!
    Steve E, BSOE, MIS
    PowerMac G5 | Dual 2.0 Ghz | 2 GB | 32GB CF | 9800XT
    AmigaOne x5000 | 8 GB | 1TB | Radeon 7770HD
  • »28.05.13 - 01:05
    Doffo
    Posts: 508 from 2010/10/14
    :) I have two 2.0 G5s and two 2.7 G5s ready for this. I will test it Thursday as I have to drive to my hometown where I have them stored.
    YUUUP!
  • »28.05.13 - 01:32
    JohnFante
    Posts: 163 from 2006/9/4
    As far as I can see there is only one G5-model listed as supported in the release notes. Maybe we can make a list here of other models that know to work :-)
  • »28.05.13 - 10:52
    Posts: 3311 from 2003/3/5
    Supported models.
    [ Edited by jacadcaps 28.05.2013 - 15:03 ]
  • »28.05.13 - 11:02
    TheMagicM
    Posts: 1220 from 2003/6/17
    wow....MorphOS will be fast as hell on the 2.7!
  • »28.05.13 - 11:12
    Zyros
    Posts: 1 from 2011/5/4
    Just installed to my G5 2.7GHz and this flies  :-o hopefully not from window..
  • »28.05.13 - 11:58
    Simon
    Posts: 809 from 2008/7/6
    Are there still things to do concerning the G5 port or does everything just work ?
  • »28.05.13 - 12:27
    Posts: 12539 from 2003/5/22
    I think the 1 GiB RAM limit is still something to overcome, if technically possible.
    Edit: added link
    [ Edited by Andreas_Wolf 30.05.2013 - 11:51 ]
  • »28.05.13 - 13:02
    BSzili
    Posts: 570 from 2012/6/8
    There doesn't seem to be any power managements options for the G5 :S Can someone who installed it confirm this?
  • »28.05.13 - 13:50
    There is none indeed at the moment.
  • »28.05.13 - 14:59
    BSzili
    Drats! My PowerMac G5 consumes 330 Watts idle at the default setting ( highest). Are there any plans to add bus slewing support in the future?
    [ Edited by BSzili 28.05.2013 - 19:05 ]
  • »28.05.13 - 15:03
    SteveE617
    {Moved to it's own topic}
    [ Edited by SteveE617 28.05.2013 - 12:47 ]
    Steve E, BSOE, MIS
  • »28.05.13 - 15:20
    Oscar
    Posts: 17 from 2011/12/11
    I hope one day that A1177 will be supported, but model A1047 covers a lot of different systems from 1.6 to 2.7GHz. Probably the most plentiful bunch around. Until then I'll be satisfied if I find a decent 2.3GHz April 2005 system. I'm not gonna bother with any liquid cooled systems.
    [ Edited by Oscar 28.05.2013 - 13:39 ]
    PowerMac G4-Dual 1.42GHz-Radeon 9600 Pro-MOS 3.1-120GB SSD
    PowerMac G5-Dual 2.0Ghz-Radeon 9800 Pro-MOS 3.2-120GB SSD
  • »28.05.13 - 15:39
    zukow
    Posts: 657 from 2005/2/9
    *SteveE617
    sounds like flashed radeon and tons of debug, check debug first :)
  • »28.05.13 - 15:46
    redrumloa
    Posts: 1424 from 2003/4/13
    BSzili,
    Yowsa! No worries, I am just happy it is out the door in a working state. It would be nice if this could be prioritized for 3.3. If not, oh well at least it shipped! Electricity is cheap here and I guess I am not currently "green" considering my recent car purchase :-D:-)
  • »28.05.13 - 16:55
    There's no A1177. Do you mean A1117?
  • »28.05.13 - 18:37
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9321&forum=11&start=1
  • »15.06.13 - 09:11
    Yasu
    Posts: 1724 from 2012/3/22
    Installing 3.2 straight from the CD (after choosing the CD in the firmware, by holding down ALT) worked great on my new (used) Powermac G5 2,7 GHz! Even though the hardware has a reputation of being unreliable (leakage) and a electric power sucker it's a nice feeling to have the fastest NG Amiga possible  :-D
    Except for a couple of problems and bugs, it works really well! Can't wait to find time to customise it :-)
    [ Edited by Yasu 15.06.2013 - 13:44 ]
    My MorphOS blog
  • »15.06.13 - 09:43
    jdryyz
    Posts: 127 from 2004/4/9
    I second the support for the A1117 model.  :-)
  • »19.06.13 - 14:22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9336&forum=10&start=6
  • »20.06.13 - 19:33
    jdryyz
    Is it just a matter of time before more hardware models are supported or does this particular Mac present some programming obstacle that has yet to be overcome?
    It would be really nice to see MorphOS running on it. In addition, it looks like the PCIe Radeon cards are currently cheaper than the AGP versions. I still have an Nvidia in my A1117 model and realize I will have to swap it out.
    I ditched my PowerMac Dual 2.0 due to lack of space and some hardware quirks that always bothered me. The Dual Core 2.3 GHz corrected everything I did not like about the Dual 2.0.
    [ Edited by jdryyz 08.09.2016 - 18:54 ]
  • »08.09.16 - 21:52
    Yeah, I'm sitting on a PCIe G5 myself.
    But as there has been no announcement that these will be supported in the future, you probably switched a bit too early.
  • »10.09.16 - 17:37
    jdryyz
    I still have my Mac mini G4. :)
  • »25.09.16 - 13:44
