pegxlin kernel
    serge
    Posts: 725 from 2003/2/20
    At this link,
    http://linux.pegasosppc.com/index.php?mode=library&submode=view&artarticle_id=2&artchapter_id=5
    I found this informations, but the kernel link is broken. Does somebody have it please?
    Q: Howto upgrade the PegXLin kernel.
    A: PegXLin is not really using a debian kernel-image package, and the kernel is somewhat old by now, probably not including my latest improvement, especially concerning ethernet and MAC less boards. The best way to fix this problem would be
    to install the kernel-image-2.4.22 package i have made available at :
    http://people.debian.org/~luther/pegasos/2.4.22/
    And install it. Then you have to move the /boot/vmlinuz-2.4.22 kernel to your FFS boot partition and boot that. (you can rename it to pegxlin if you want). The kernel-image package also will install the needed modules.
    Thnx
  • »19.03.04 - 17:09
    MacFly
    Posts: 37 from 2003/10/14
    Hi Serge
    what about this http://mirrors.pegasosppc.com/files/linux/pegxlin/pegxlin.iso
    its a complete installation everything you need
  • »19.03.04 - 20:54
    Posts: 979 from 2003/6/28
    What about 2.6.x kernel?
    What about R/W full SFS support?
    What about integrate Pegasos I & II support on linux kernel official branch?
  • »19.03.04 - 21:15
