Pack Chrysalis beta for MorphOS 3.9 available
    Posts: 12569 from 2003/5/22
    > by mounting chrysalis iso and then by scanning this volume virusz warned
    > me of the virus 'happy new year 96' in 68k parts of audio prostration.
    Yes, reported there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10551&forum=3&start=18
    > the site does not seem to exist www.audiolabs.it for [...] a year and half or two years.
    It was still there in December 2014.
    http://web.archive.org/web/20141219112609/http://www.audiolabs.it
    > I do not know if psa was already infected at its author
    Unlikely.
  • »10.01.16 - 20:35
    > Is it correct to assume that any virus in the Chrysalis.iso is not activated
    > and spread until it is installed, or can just copying the iso file to your
    > hard drive infect my computers?
    Neither. The infected files would have to be executed.
  • »10.01.16 - 20:42
    Papiosaur
    Posts: 2615 from 2003/4/10
    I have removed the ISOs from the server.
    I will release a new clean version soon.
    To all users of Chrysalis pack, to remove this old 68k virus you must scan with VirusZ available on Aminet.
    Sorry for this desagremnt.
    papio
  • »11.01.16 - 03:37
    Posts: 1932 from 2003/10/19
    When is this going to return? I need another copy for a new install.
  • »19.02.16 - 21:46
    TheMagicM
    Posts: 1220 from 2003/6/17
    same. Have a new user running a G4 that will need this.
  • »20.02.16 - 15:25
    Papiosaur
    Hello,
    thanks for your interest for the pack !
    a beta version is available on this link :
    http://www.warmup-asso.fr/download/pack/chrysalis_beta.iso
    Don't hesitate to do remarks, suggestions on this thread to improve and to finalize the pack.
  • »27.02.16 - 13:42
    Posts: 88 from 2015/10/29
    Hi, I am new to MorphOS and just now got to try Chrysalis for the first time. I did a clean install to my powerbook and I can't believe all the things in there. I really appreciate it. I have two things I am hoping to get some help with.
    1. There are new menu items, some across the top in the ambient bar and some things in my RMB context popup menu that are not in English. Most of my system is still in English and I checked my Local setting and they are set for United States and English with no other languages chosen. How do I get these to display in English, they appear to be in French. (Note: Not all items in these menus are in French. Thins like "Extract" and "Extract here" are all in French now. But most of the menu, the top part, is still in English.
    2. The OWB installed by Chrysalis doesn't play YouTube Videos...at all.... All I get is a black windows where the video should be playing. No audio, no video, no controls on the screen for it. Just a blank place where it all should be.
    [ Edited by DFergFLA 27.02.2016 - 21:26 ]
  • »28.02.16 - 00:09
    I remember this has already been reported:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11466&forum=53
  • »28.02.16 - 05:34
    beworld
    Posts: 683 from 2010/2/10
    ok we check that ^^
    Normally, after the extraction of the "chrysalis.lha" file, the archive "english.lha" must also be extracted.
    it is in this file that typemines in English are present.
    Have you seen the extraction of english.lha file?
    My MOS ports
  • »28.02.16 - 06:08
    Papiosaur
    Hi DFergFLA :
    in first, thanks a lot for your returns.
    1. Try to extract Chrysalis:archives/english.lha to sys:
    Maybe an error in installation script or in crabum.rexx file, i verify that.
    2. I will try this new script, thanks Andreas_Wolf ;-)
  • »28.02.16 - 06:17
    @ Papiosaur
    Thank you, I can report that most of the issue is resolved. The only things I didn't see change back over to English were, the Crabum.rexx script in WBStartup and the Daily Tip in WBStartup. these remained in French. I removed them from startup so I'm fine.
    If you could consider including the mp3 tag library: http://aminet.net/package/util/libs/id3tag_lib It is nice in that it allows DAPlayer to read and display the mp3 data in it's gui, it just makes a nicer end user experience..
    Thanks
    David
  • »28.02.16 - 18:35
    TheMagicM
    How long till its out of beta?
  • »01.03.16 - 01:56
    Posts: 14 from 2013/9/6
    Thank You for all your hard work getting this together. I haven't upgraded my OS or Chrysalis in a couple of years great to see some huge changes. You guys rock !!!
  • »01.03.16 - 17:42
    beworld
    Hi all !
    last version is availible !
    http://www.warmup-asso.org/articles.php?sid=2048
    My MOS ports
  • »14.03.16 - 05:33
    Posts: 1 from 2016/4/10
    Hi everyone!
    I am new to this, so I don't know if I am installing Chrysalis the right way.
    I have downloaded the .iso, I have mounted it with right click, i double-clicked
    "install chrysalis", I've chosen SYS:, and then I get the message "Please wait until the extraction then click on Continue", While I see "extracting" on top... How long does it takes for the "extracting" message to change so I can press continue???
  • »10.04.16 - 18:25
    redrumloa
    Posts: 1424 from 2003/4/13
    Are there any mirrors? Your server keeps canceling the download.
  • »10.04.16 - 21:42
    Papiosaur
    @raidomains:
    we have changed the text in installer script during the extraction in last version.
    You must click to Continue button when the extraction is finished.
    @redruloa: try button in down on this page please:
    http://www.warmup-asso.org/download.php?op=geninfo&did=1
    @all: thanks to all for your feedbacks about the Chrysalis pack, we need it to improve it ;-)
  • »11.04.16 - 02:38
    redrumloa
    I did end up getting a complete download, I just had to restart/resume it about 30 times :-p
    Thank you.
  • »11.04.16 - 12:12
    redrumloa
    FYI I found a small problem. This creates a folder in Locale for dictionaries but is misspelled.
    Overall, looking good.
  • »17.04.16 - 17:01
