Asian Locale Support
    drphil
    Posts: 36 from 2015/11/28
    Does anyone know if there is a way to add Asian locale support to MorphOS?
    Would be handy for web surfing and helping some sites in asian script render properly
    1.6Ghz PowerMac G5, 2GB RAM, 80GB HDD, MorphOS 3.9.
    Why make life difficult when with a bit of effort you can make it impossible
  • »06.12.15 - 03:06
    BSzili
    Posts: 570 from 2012/6/8
    OWB already renders them just fine:
    http://fab.morph.zone/owb/owb-morphos-1.24.readme
  • »06.12.15 - 05:59
    Posts: 1521 from 2003/2/24
    Languages that fit to 8-bit codesets can be supported.
  • »06.12.15 - 07:20
    drphil
    Do I need to change the font settings to view websites with Chinese characters?
    Cheers
    Philip
  • »06.12.15 - 23:52
    drphil
    ASCII doesn't support Chinese characters, so I'm guessing not?
  • »06.12.15 - 23:55
    Posts: 848 from 2007/10/23
    Use Kochi font
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7178&forum=9
  • »07.12.15 - 06:20
    Jeckel
    Posts: 133 from 2007/3/11
    The two things are not related.
    1.You can display any language within the web browser. Just have a look at the linked file for the explanations (basically you need to install and configure the appropriate font).
    2.You cannot use anything else than 8-bits characters (btw 8-bit charset is not ASCII!) in the operating system (and applications) itself.
    It means that you can browse Chinese websites, but that you could not use Chinese characters in a wordprocessor or a text editor for instance.
  • »07.12.15 - 06:20
    At least Multiview supports UTF-8 :-)
  • »07.12.15 - 06:46
    drphil
    Ah
    Now I understand
    Thanks guys!
  • »07.12.15 - 16:31
    Nadir
    Posts: 178 from 2003/3/17
    And so does Scribble. Anyhow, this is definitely an area where there is scope for progress...
  • »07.12.15 - 22:16
    Yasu
    Posts: 1724 from 2012/3/22
    If MorphOS got Japanese support I will be happy to translate it to Japanese ;)
    My MorphOS blog
  • »08.12.15 - 09:11
    drphil
    Likewise! If MorphOS added support for Simplified Chinese, I would be more than happy to help with translation :-)
  • »09.12.15 - 04:21
