How to install Chrysalis 3.9.1
    Punkyclown
    Posts: 37 from 2015/2/15
    Hi, I just installed MorphOS on my Mac Mini, great. Now I have burned Chrysalis to
    DVD but I can't seem to get it to install on my system. Did I miss a step?
    Thanks
    Brad
  • »30.10.15 - 00:08
    Thanks
    Brad
    What error message are you getting when you double click on the Chrysalis icon?
  • »30.10.15 - 13:45
    Punkyclown
    Thanks, but that's just it, I did click on the install file and it went through the
    install steps and but nothing happens. Then it tells me that the install
    is finished... But nothing has changed. Strange
  • »30.10.15 - 20:34
    Punkyclown
    Okay, Sorry there was an error message, it was that LHA was unable to open archive.
    It goes through asking me where I want to install, Sys:? Then if I want to install games
    and where, then if I want to install Emulators and where, then it returns with the erro message??
    The last time I installed Chrysalis, it didn't do any of this, it just opened the file and started installing
    the upgrade.
    Thanks
  • »30.10.15 - 21:30
    Punkyclown
    Hi, No matter how I try to install Chrysalis, from disk or from saved file.
    I get the same repsonse. Fail to open archive. I downloaded it on my
    MorphOS system. Put the iso in the Work drive. When I try to load it from
    there it goes through the same requesters and then ask my to load MorphOS
    disk. When I try to load from disk, it says return code 20 fail to open Archive.
    I am really stuck on this and it's a drag.
    How do I mount the disk on my desktop from a saved file?
    Thanks
    Brad
  • »01.11.15 - 19:45
    Posts: 2217 from 2003/2/24
    Right click the ISO file and select "Mount" to mount it properly. Doubleclicking the file doesn't mount it properly and may cause some issues if you try to run installers by browsing the ISO that way.
  • »02.11.15 - 04:17
    Punkyclown
    !!Success!! Hey guys, thanks so much, got Chrysalis installed and it is Terrific.
    Really appreciate the help!
    Brad
  • »02.11.15 - 20:52
