Posts: 1609 from 2012/11/9
If it's just an image (PNG or JPEG) that you want of your screen or even part of your screen (which does not include part of an MPlayer GUI screen image) then
SnapIT should suit your needs very nicely.
I use it a lot, and you can even "lasso" a section of the screen, and you can choose to save screengrabs incrementally, to a set destination, so it is very useful - well it is for me.
