OWB bugs
    Cool_amigaN
    Posts: 777 from 2011/11/30
    @Fab
    Well, I amazed to find out that both Gmail and Facebook have kept my passwords. I am using the machine for MorphOS display and I don't want accidentally someone to start browsing on my mails. Is it possible to erase the password once stored?
    Btw, yesterday I tried to make a transaction on PayPal (renew my AF subscription) but I ended up on this error. Does it have anything to do with libcurl or something? I tried with different spoofing combinations/java enabled disabled etc, but nothing worked.
    EDIT:
    Also, this yt video doesn't work on fullscreen (fullscreen button doesn't seem to respond).
    [ Edited by Cool_amigaN 04.07.2014 - 10:22 ]
  • »04.07.14 - 06:20
    Posts: 12570 from 2003/5/22
    >> Some passwords can also be stored and restored with cookies/javascript
    If it's stored in the cookies, well, delete the relevant cookies I'd say. There's also the HTML5 local storage in /conf/LocalStorage/ which I guess may be able to store passwords. You can delete this as well.
    JavaScript.
    Fullscreen button works fine here.
  • »04.07.14 - 07:34
    Cool_amigaN
    I've revered to OWB 1.23 (including the scripts) and fullscreen button started to reply again.
    @r-tea
    Unfortunately mine issues remain, regardless of the version installed (1.23/1.24). Perhaps I will try an even older version because it's a pity having OWB crippled with PayPal :(
  • »07.07.14 - 09:16
    Button works here with v1.24. No scripts, no spoofing, no HTML5 beta required. Just works.
  • »07.07.14 - 17:26
    NewSense
    Posts: 1618 from 2012/11/9
    I thought I had an issue with ebay the other day when my PURCHASE HISTORY page loaded - but was BLANK, that means the ebay page itself loads, so that the menu loads on the left, and the header and footer information are shown but NO PURCHASES - NO LIST of items bought is shown at all.
    I flushed the cookies for ebay (all of them) and still have the same problem. I contacted ebay who said all was OK at their end, and now that I have switched on my Windows system and run Firefox the Purchase History page loads OK.
    So, I can only think that ebay have recently changed some part of their Javascript for that page which is not supported in OWB.
    I was using OWB v1.24, but have also tried OWB v1.22 and get the same result with both versions of OWB.
    Unless someone else has another solution to fix this issue? 8-D
    EDIT: I have since learned that ebay have definitely changed the format of the PURCHASE HISTORY page, and added a couple of options onto the page, and I feel sure this is what OWB cannot handle, so until it gets fixed the ebay Purchase History page will remain 'broken' as far as OWB is concerned
    EDIT2: I have returned to the ebay Purchase History page, and now find that it is working as it should again with OWB, so what the problem was with it I have absolutely no idea.
    So that's one problem solved, but the issue with the Gumtree website still continues and I cannot update any of my adverts with OWB, and have to rely on dropping back to Windows or Mac OSX and use one of the browsers on those platforms to do any editing I need for adverts I have on that website.
    I know it's not a major problem, but OWB still needs fixing for that website.
    [ Edited by NewSense 31.07.2014 - 23:53 ]
  • »25.07.14 - 20:08
    NewSense
    I was trying to track a package via the courier Hermes, but they have changed/altered some of their site features, so when you try to track a parcel now you get a requester about accessing the site - error 35: SSL connect error.
    I have a bookmark set that allows me to access their website through another page for these tracking features but most people will not have this option, and will only utilise the parsed one from ebay.
    So the default/parse from ebay to this website for the tracking of a package I sent will not allow me to use the tracking on the Hermes website, so this is a limitation of the SSL features that are part of OWB, and needs fixing. Please ;-)
  • »18.08.14 - 13:00
  • ede
    ede
    Posts: 35 from 2011/4/18
    It seems to be downloading files from Google Drive isn't working. Is it just me? :)
  • »28.08.14 - 11:30
    NewSense
    Can't help you with the Google drive issue, as I don't use it, but ...
    I also wondered if it would be possible to allow a right mouse click on a bookmark to be able to offer the option of Open, or Open in a Tab, or Open in New Window - as is allowed on a Quicklink-ed bookmark button - which is based on a bookmark anyway, but at the moment opening a bookmark only opens in the window/tab that is currently active.
    Even a historically closed entry opens in a new Tab, but a standard Bookmark seems to have missed out on this beneficial feature/option.
    I also wonder when the Ctrl + 1/2/3/4/5/6/7/8/9/0 option to move from one Tab to the relevant numbered one will work - even when you are not in the upper area of the GUI, as it doesn't work when you are in the webpage display area of OWB - which seems a bit ridiculous really - maybe an additional qualifier key like Shift would solve this issue, so Ctrl + Shift + 1/2/3/4/5/6/7/8/9/0 - rather than having to click first-of-all in the upper menu / navigation area of the GUI to be able to activate this Move-to Tab feature.
  • »11.09.14 - 20:09
    NicePics13
    Posts: 63 from 2007/3/9
    PayPal seems to be working (again?) with OWB 1.24 and the updated ca-bundle.crt from http://curl.haxx.se/docs/caextract.html
    CBM Amiga 1200 + 4MB AMITEK with 33MHz 68882 FPU
    PowerBook5,4 1024MB 1333MHz G4
  • »28.03.15 - 11:56
    Posts: 848 from 2007/10/23
    Thanks!
    wget https://raw.githubusercontent.com/bagder/ca-bundle/master/ca-bundle.crt --no-check-certificate
    copy ca-bundle.crt TO SYS:Applications/OWB/curl-ca-bundle.crt
  • »28.03.15 - 17:50
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I don't see what you mean. In bookmarks window, there's also a contextmenu showing all these options. And with the middle mouse button you can even open the clicked bookmark in a new tab.
    At least you can use ctrl + page up/down to navigate to your tabs, if the ctrl + n option doesn't work as expected.
  • »29.03.15 - 11:17
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    well it works here, also when focus is within the webpage area. But it only works when using the number keys on the numpad ! Have you tried this ?
  • »29.03.15 - 20:03
