Beginners Discussion
    TomKeric
    Posts: 146 from 2013/2/18
    Hi everyone, I wanted to propose to the admin of MorphZone to add a user forum for beginners. "Beginners forum"
    That could be a place for me and everyone else that is in need of learning fundamentals in MorhOS as well as propose improvements for easier understanding for newbies.
    Its something I believe would help a lot. but of course only if the skilled users help out and write in an "easy-to-understand" manner
    BTW you may say I been onboard for a wile but actually I just came back with a new PPC since my previous one was stolen at a burgerly in April ;)
    Merry X-mas
    -If you've never failed, you've never tried -
  • »22.12.14 - 18:28
    Yasu
    Posts: 1724 from 2012/3/22
    www.morphosuser.wordpress.com ;-)
    My MorphOS blog
  • »22.12.14 - 18:42
    TomKeric
    Thanks Yasu. I am going to read the wordpress blogg now !!
    A lot of things seems to have happened since I was hear earlier 2014.
    One thing I noticed is that the wireless works directly from native Mac Mini now. (Awesome) However I noticed it does not run perfectly well (in my home at least) so I tested to attach my iPhone6 with the USB cable and phone internetsharing switch "on" and WOW that was like bringing the old Mac Mini with MorhpOS to 2015. And super easy to do.
  • »22.12.14 - 18:54
    TomKeric
    Here is 3 questions of mine if anyone has a link / answer:
    1) I cant change the clock time. it is going on UK time and I need to move it to +1 hrs. the top bar flashes red when I try to change the clock.
    2) My usernames and passwords seems to always be forgotten in OWB, I like to get it to remember/part remember for more simple re- usage
    3) I like to place icons triggering URL links on my desktop and change the icons to my icon files.
    Thanks a lot
    /Tomas
  • »22.12.14 - 19:57
    TomKeric
    2 other matters I have:
    1) everytime I start up the MOS I get a message "RX Output"
    +++ Error 6 in line 124: Unterminated comment
    Command returned 10/6: This space intentionally left blank!
    What does this mean and how can I get it to go away?
    (I run MOS3.7 and latest Chrysalis)
    2) How do I turn of the startup chimes on the Mac Mini. I remember I managed to get it turned off on my old Mac Mini but cant remember how I did it. I only run MOS on this one. The old one I had dual OS.
    Thanks
  • »22.12.14 - 20:13
    Posts: 12569 from 2003/5/22
    http://www.amiga.org/forums/showpost.php?p=773923
  • »22.12.14 - 22:23
    In_Correct
    Posts: 245 from 2012/10/14
    I think this new forum is a good idea. I am a newcomer to MorphOS and occasionally I can have many silly questions. I don't know if I need to read all those blog sites yet because I can figure out how to use a MorphOS computer mostly by myself but sometimes I have specific questions and I enjoy getting the answers quick response on the forums. A dedicated forum will be most useful. :-) apologies for possibly asking what could be a FAQ, and also I should be sorry for posting very long sentence.
  • »22.12.14 - 23:57
    In_Correct
    I see MorphOS has official FAQ page. Can this be updated also?
  • »22.12.14 - 23:59
    Papiosaur
    Posts: 2615 from 2003/4/10
    @TomKeric :
    i must correct this error in pack Chrysalis 2015:
    "+++ Error 6 in line 124: Unterminated comment
    Command returned 10/6: This space intentionally left blank!"
    To correct it, just add a "'" at begin of the line 124...
    @In_Correct : I have open a non official FAQ on www.warmup-asso.org
    http://www.meta-morphos.org/faq.php
    I must updated too :-D
  • »23.12.14 - 05:35
  • ASiegel
    Posts: 1397 from 2003/2/15
    It´s been added. You will find it here:
    Beginners Forum
  • »23.12.14 - 06:34
    TomKeric
    Thanks Andreas, adding the missing ´ in line 124 solved it
  • »23.12.14 - 10:14
    TomKeric
    Papiosaur wrote:
    @TomKeric :
    Thanks Papisaur, the line 124 in WBstartup I added a ´ proposed in the link from Andreas and it solved if
  • »23.12.14 - 10:16
    TomKeric
    Beginners Forum
    Cool thanks ASiegel,
    the link however returned to me that I don´t have the proper rights,
    Br/Tomas
  • »23.12.14 - 10:18
    connor
    Posts: 650 from 2007/7/29
    Beginners Forum
    I get the meassage
    You don't have the right to access this forum.
  • »23.12.14 - 10:22
    TomKeric
    Here´s issues nr #6 and #7 from me:
    #6 when starting OWB I get the error message "Net Stack Log"Tue Dec 23 12:23:31 2014 [err ]: : iface_config: SIOCAIFADDR: Object exists
    (OWB and wireless workes fine though so no obvious problems experienced)
    #7 if I ctrl+C outside OWB to copy this error message to the forum OWB shut down and cannot be restarted, I need to restart MOS to be able to restart OWB. Any clue why the ctrl+C gives me this outcome. ctrl+c inside OWB does not give this result
    issue 1-3 + 5 pending answer
    #1 I cant change the clock time. it is going on UK time and I need to move it to +1 hrs. the top bar flashes red when I try to change the clock.
    #2 My usernames and passwords seems to always be forgotten in OWB, I like to get it to remember/part remember for more simple re- usage
    #3 I like to place icons triggering URL links on my desktop and change the icons to my icon files.
    #4 Solved
    #5 How do I turn of the startup chimes on the Mac Mini. I remember I managed to get it turned off on my old Mac Mini but cant remember how I did it. I only run MOS on this one. The old one I had dual OS.
    Thanks everyone if you anything about this please give me a hint/link
  • »23.12.14 - 10:28
    TomKeric
    #4 Solved
  • »23.12.14 - 10:29
    TomKeric
    Beginners Forum
    Asiegel the link returns that I dont have the rights to go there
  • »23.12.14 - 10:30
  • ASiegel
    Please try again.
  • »23.12.14 - 10:44
    faariwasi
    Posts: 1 from 2014/12/23
    Well, you may have heard that WinUAE has got/will get CyberstormPPC emulation, too. Current state of WinUAE with PowerPC is rather like a proof of concet (slow and not too stable), but maybe in future (when a ppc JIT will be avalable) speed will reach levels where is actually provides something useful.
    ______________________________
    Our excellent online ccna security training programs will lead you to success in the C4090-455 We also offer latest Pass4-sure and www.principiacollege.edu with 100% success University of New Haven good luck.
  • »23.12.14 - 13:38
    Yes, it was released 6 days ago, also including BlizzardPPC emulation.
    > (slow and not too stable), but maybe in future [...] speed will reach
    I read it's rather fast (faster than Sam460 with certain tasks on recent hardware), except for FPU code, and also very stable.
    WinUAE's PPC emulation (which is QEMU actually) *does* have JIT.
  • »23.12.14 - 14:07
    TomKeric
    ASiegel wrote:
    Please try again.
    It works!! Thanks sweet
  • »24.12.14 - 15:05
    TomKeric
    [Tread closed - open issues moved to the new beginners forum]
  • »26.12.14 - 10:56
