Mac adress
    metalmac
    Posts: 87 from 2007/5/26
    Hi!
    A newbee question for you! ;)
    How do I se the Mac adress on my built in apple airport card in MorphOS 3.7?
    I want to ad my PowerBook to my wireless router.:)
    PowerBook G4@1.5Ghz, 1Gb ram, MorphOS 3.12
    Amiga 1200, Blizzard 1220/4@28Mhz, 500Mb HD, 6mb RAM, Workbench 3.1
    AspireOne, 1Gb RAM, 160Gb HD, Icaros Desktop
    AmigaOne 500, 2Gb ram, AmigaOS 4.1 Final Edition
  • »01.11.14 - 17:36
    metalmac
    Thanks, but that command did not help me. :(
  • »01.11.14 - 19:36
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    Why did it not help ?
    Neuer Shell-Prozess 9
    Ram Disk:> ifconfig
    lo0: flags=8009<UP,LOOPBACK,MULTICAST> MTU=16436
    inet 127.0.0.1 netmask ff000000
    Hardware type: Loopback
    wl0: flags=4863<UP,BROADCAST,NOTRAILERS,RUNNING,SIMPLEX,SANA> MTU=1500
    inet 192.168.1.11 netmask ffffff00 broadcast 192.168.1.255
    Hardware type: Ethernet, address: 0:f:b5:23:b5:94
    Use "ifconfig -h" for usage.
    Ram Disk:>
    The bold text is my mac of the pccardbus wlancard
    The same with your internal active interface
  • »01.11.14 - 20:28
    metalmac
    I found the application now, under System:Tools you have the NetStat, there you find everything. :)
  • »01.11.14 - 20:32
    pegasos-sigi2
    Netstat get its info from ifconfig, too :))
  • »02.11.14 - 08:41
