Posts: 1576 from 2012/11/9
What MorphOS program are you using to listen to the amigavibes.m3u link?
I used to attempt to load such .m3u files via MPlayer, but had no success initially, and raised this subject in this forum, on a different thread, but recently I discovered that MPlayer does actually now work with such .m3u type files, but after adjusting the cache upwards a small amount I find that it takes until the track has ended for a CTRL+C command to stop MPlayer from actually quitting or stop playing the streamed file.
I managed to listen to this AmigaVibes Radio - very listenable to, and nostalgic.
MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
