Release date of new Chrysalis Pack for MOS 3.5?
    WeiXing3D
    Posts: 327 from 2012/6/13
    Is there any update on the release date of the new Pack Chrysalis for MOS 3.5?
  • »03.04.14 - 13:58
    Papiosaur
    Posts: 2430 from 2003/4/10
    I work on it, i try for this week-end :-D
    This is the link for the beta-test version if somebody want to test it:
    http://www.meta-morphos.fr/download/pack/Chrysalis-3.5.1_beta.iso
    [ Edité par Papiosaur 03.04.2014 - 19:14 ]
  • »03.04.14 - 14:13
    JuLieN
    Posts: 35 from 2008/4/16
    The beta version works perfectly for me, Papio. :) Thanks for your great work !
    "A good bug is a dead bug" (Don Dailey)
  • »05.04.14 - 20:59
    WeiXing3D
    @papiosaur - are you skipping Chrysalis 3.5.1 to go straight to 3.6.1 with wifi support?
  • »20.04.14 - 17:54
