I need a polish tester for V.A.M.P. 1.10
    Templario
    Posts: 561 from 2012/4/28
    I'm working join with Czesiu Mnich in the translation of V.A.M.P. text to polish, this translation is showed perfect in the Windows version but not with the AmigaOS4 version and I need if the MorphOS version the text are show fine or with problems with squares, here is there any Polish user?
    Download from here: www.vamp.pm/VAMP-MOS.lha
  • »23.03.14 - 09:57
    Posts: 1362 from 2004/2/8
    Uhm... The link doesn't work? The site doesn't work also. It says like: "vamp.pm is hosted by One.com"
  • »26.03.14 - 18:10
