Wireless rj45 dongle
    droopy
    Posts: 35 from 2013/12/12
    I have an rj45 to wireless dongle.. it works fine on my a4000
    trying to get it to work with morph os to.
    I have "some" life on it the dongle comunicartes with my wifi network and shows up at my router..(I use static IP)
    problem I have is that I can not find any drivers exept the default
    sungem_eth.device:0
    is this the one that is supposed to work?
    In netstat.. no connections in the list..
    interfaces I have
    eth0 my static IP and netmask
    routes
    default 197.168.1.1 UGc eth0
    Default 0.0.0.0 Uc
    localhost 127.0.0.1 UH
    192.168.1.0 192.168.1.19 Uc eth=
    flags dont tell me much
    where to start troubleshooting ?
  • »28.12.13 - 15:46
    defender
    Posts: 249 from 2011/4/24
    Hi droopy,
    please type the command ifconfig and print the output here.
  • »28.12.13 - 16:21
    defender
    Default 0.0.0.0 Uc
    this is just a fault in typing, i guess?
  • »28.12.13 - 16:25
    Posts: 12570 from 2003/5/22
    > sungem_eth.device:0
    Yes.
  • »28.12.13 - 17:49
    droopy
    @defender yes it was a typo in the forum by me. I found the problem thou.
    I have 2 of the dongles (cheap china ones http://www.ebay.com/itm/Mini-2-4Ghz-RJ45-Wireless-WiFi-Bridge-AP-for-Dreambox-xBox-PS3-PC-Camera-White-/181289639559?pt=LH_DefaultDomain_0&hash=item2a35b45e87
    By default the wifi bridge dongle had an IP as 192.168.0.250
    when changing the dongles ip to 192.168.1.250 I got the connection to work fine.
    For me wireless is quite important sine I live in a lightning struck area and have lost a lot of modems and computers.. Atleast with wireless I only loose the modems now.
    tanks for the help thou..
  • »29.12.13 - 08:24
