PowerSDL 16.0b
    Posts: 1521 from 2003/2/24
    I have just updated PowerSDL to version 16.0b. Only change here is in smpeg.library which in previous version trashed OpenGL context used in main powersdl.library and some games using smpeg failed to work. This is now fixed.
    To developers there is a constructor free libSDL-nc.a (see SDK) if you have to avoid using SDL constructor in your shared library project.
  • »05.12.13 - 17:37
    tolkien
    Posts: 578 from 2013/5/29
    Great to see SDL updates! Thanks itix!
  • »06.12.13 - 09:05
    eastone
    Posts: 47 from 2007/8/4
    http://www.youtube.com/watch?v=SkFlqxC-Ork
    Does anyone have the same problem with sound in E-UAE and PowerSDL16 ?
    With PowerSDL14 everything is OK.
  • »06.12.13 - 16:54
    _DaNi_
    Posts: 154 from 2010/5/4
    thank itix now testing you new version with the sdl morphos software :) a lot of thanks for your hard work! :)
  • »07.12.13 - 23:54
