Posts: 874 from 2007/4/9
thaddaeus wrote:
ive got a belkin 150 wifi adapter that works fine with my imac hopeing to use this . wifi hot spot from my android samsung phone just worked without doing anything other than turning on wifi on my imac . it dont expect this on morph .
where do i go to enter in ip adress and such in morph. saw somthing at install but i skipped it where do i access it now? i have the ip adress of my phone.
the slow down message box says to use regtool application am i supposed to get this from teh website under the message? i couldnt find it in applications folder.
reda the tip of teh day on how to open the browser from the command line
an ethernet to wifi bridge waas mentioned to me in a post on amigazone
thank you
Configuring your network connection
In order to browse the internet, check e-mail or download software, a network
connection must be configured.
It is assumed in this guide that you have a standard setup with a router to
which all computers are connected.
If you have a different setup, and/or experience trouble configuring your connection,
please ask for help.
- Configuring a wired internet connection
Connect one end of a network cable to a spare port on your router, and the other
end into the network port of your system. If your system has more than one network
port (eg Pegasos 2 has two onboard network ports) make sure to note which port is
used.
Boot your MorphOS system.
-- Automatic configuration
MorphOS included network stack supports automatic configuration via DHCP.
If your router is set to automatically configure attached devices (ie DHCP server
is enabled) then your MorphOS system should automatically configure itself upon
system boot.
If your router is not set up to automatically configure attached devices, or your
system fails to obtain an IP address from the router, see the 'Manual
configuration' section below.
-- Manual configuration
MorphOS makes configuration of the network connection very simple.
You will need to know your router's IP address (eg 192.168.0.1), and an available
IP address to use for your MorphOS system (eg 192.168.0.101).
RMB on desktop>Settings>System..>Network
In the Network Interfaces tab, expand the entry for your network connection:
(On mac-mini this is sungem_eth, Pegasos 2 rhinevia, blah, etc)
Enter an IP address for your MorphOS system (eg 192.168.0.101)
Enter Subnet Mask (255.255.255.0)
Enter Gateway - your router's IP address (eg 192.168.0.1)
In the Host and DNS tab:
(Optional) Enter a hostname to identify your system on the network (should be
unique on your local network). Ideally this should be 8 characters or less.
Enter at least one, and up to 3 DNS server addresses.
On a standard network, entering your router's IP address should be sufficient.
www.hullchimneyservices.co.uk
Windows free since 2011!
