Just for fun...
    SteveE617
    Posts: 80 from 2013/1/26
    I updated my blog with some of my Amiga history. If you'd like to see the Amiga's I've had through the years and some history I have had with them, check out my blog "Planes, Plastic, Silicon and Strings" at:
    http://stevev22fe.wordpress.com
    While there, you can see some of my other interests...
    [ Edited by SteveE617 14.06.2013 - 21:39 ]
    Steve E, BSOE, MIS
    PowerMac G5 | Dual 2.0 Ghz | 2 GB | 32GB CF | 9800XT
    AmigaOne x5000 | 8 GB | 1TB | Radeon 7770HD
  • »15.06.13 - 02:38
    Derringer
    Posts: 103 from 2008/8/4
    Man, You owned a Bodega Bay? I chase it to get one, but never happened at the '90. You're lucky.
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »16.06.13 - 08:51
    SteveE617
    Yes. It was really neat to have one. I really enjoyed it at the time, but when I got the 2000, there were much more advantages to it over the Bodega Bay
    Steve E, BSOE, MIS
  • »16.06.13 - 15:38
