Ultimate Pack is offline?
    muffie
    Posts: 38 from 2012/2/24
    Hey, where can I download the Ultimate Pack? 3.1.1 links are 404 (http://meta-morphos.org/download/Pack/ultimate.iso)
    The pack is dependent on the OS version?
    - BTW, can I download the ISO on a PC and transfer to the Powerbook on a flash drive?
  • »28.05.13 - 15:59
    cip060
    Posts: 153 from 2010/7/30
    No works just reload the page a few times when not charging it also happens with the site sometimes
  • »28.05.13 - 16:12
    Posts: 2732 from 2003/2/24
    Also note that (AFAIK) versions of the pack are tied to specific MorphOS versions, and shouldn't be installed on other versions of MorphOS than what it was made for. I'm sure there will be a version for MorphOS 3.2 very soon.
  • »28.05.13 - 16:15
    muffie
    Tried several times:
    Error 404 - Not found
    Le fichier requis n'a pas été trouvé. Il peut s'agir d'une erreur technique. Veuillez réessayer ultérieurement. Si vous ne pouvez pas accéder au fichier après plusieurs tentatives, cela signifie qu'il a été supprimé.
    But, as "take me home grandma" (gee, is that nick right?) said, its maybe better to wait for the 3.2 version...
  • »28.05.13 - 16:22
    Papiosaur
    Posts: 2620 from 2003/4/10
    Hello all,
    thanks a lot for your interrest about the pack Chrysalis (old Ultimate) :-D
    Yes, the pack is dependent on the OS version, I preferred to remove the ISO image dedicated to MorphOS 3.1 for fear of incompatibility.
    A dedicated version for MorphOS 3.2 will be released as soon as possible.
  • »28.05.13 - 16:30
    muffie
    By the way, the last time I tried, I remember that after running it, it started to download everything.
    With my connection (if I remember correctly) it was impossible to be able to download everything within the 30 minutes period.
    The ISO has everything included?
    Best Regards,
  • »28.05.13 - 16:52
    muffie
    Still waiting! :)
    If you need someone to beta test it, let me know...
  • »30.05.13 - 12:37
