PB 5.6 & Mini: Not being able to boot 3.2 CD
    Yasu
    Posts: 1724 from 2012/3/22
    Guess who was eager to update to 3.2!  :-D
    However, I'm not getting anywhere. Pressing C or ALT in either my PB or Mini only reveals my HDD and not my CD-reader. And just inserting the CD doesn't work at all (works fine on 3.1). All I get is this message:
    (btw, tried to do as it says as well. Doesn't work)
    The errors are identical to both machines and I've burned two separate CD:s just in case and they both have exactly the same problem.
    Remember, I'm a noob. I need some serious help/guidance here.
    [ Edited by Yasu 27.05.2013 - 23:23 ]
    My MorphOS blog
  • »27.05.13 - 19:22
    Papiosaur
    Posts: 2615 from 2003/4/10
    - mount kernel partition (Boot: partition) if not available.
    - rename the old boot.img and copy the new boot.img to the kernel partition (Boot: partition)
    - reboot
    - Press C and install via CD
    or type
    boot /pci/cd from openfirmware :-D
    [ Edité par Papiosaur 27.05.2013 - 23:54 ]
  • »27.05.13 - 19:34
    stephen_robinson
    Posts: 746 from 2007/4/22
    That didn't work for me on my macmini until I copied over everything from the cd0: mac_ppc32 folder onto my Boot: drive, the macodboot and all that.
    I'd recommend backing everything up on the Boot: drive first of course, but maybe even wait until they fix the cd image.
    Wonder if it's possible to copy the mac_PPC64 onto a boot: partition on a G5 Powermac and install that way? Dunno, I've managed to get it on my Macmini, and that's enough for me tonite.
  • »27.05.13 - 19:48
    Yasu
    I'm not sure how to do that.
    My MorphOS blog
  • »27.05.13 - 19:49
    Yasu
    I prefer not doing complicated stuff I don't really understand. Not unless I absolutely have too.
    Why is this update procedure so much more complicated than between 3.0 and 3.1? In that case it was just to insert the CD and let the installer do it's magic.
    I really hope the MOS Team will fix the ISO and make the install process as pleasantly easy as before.
    My MorphOS blog
  • »27.05.13 - 19:58
    Yasu
    Found this text at a Swedish forum:
    Es gibt wohl einen Fehler in aktuellen ISO, der anscheinend alle Apple Geräte betrifft. Nach der genauen Fehlerquelle wird derzeit intensiv gesucht, damit eine gefixte Version schnellstmöglich bereit gestellt werden kann.
    Wer also nicht gerade auf CDRW schreibt, sollte sich die Rohlinge sparen, bis Entwarnuing gegeben wurde.
    Geit
    Google translate: "There is probably a bug in current ISO, which appears to affect all Apple devices. After the exact source of error is being intensively sought for a fixed version can be made ​​available as soon as possible.
    So who's not writing to CDRW, the blanks should save, was given to Entwarnuing.
    geit"
    My MorphOS blog
  • »27.05.13 - 20:06
    Posts: 12570 from 2003/5/22
    > Found this text at a Swedish forum: [...]
    That's German, not Swedish :-) The .de TLD in the URL hints at that ;-)
  • »27.05.13 - 20:41
    Posts: 2095 from 2003/6/4
    Open sys:tools/mounter and mount the hfs boot partitition manually. Copy boot.img from the CD's drawer mac_ppc32 to that partitition. Inser CD (if not inserted anyway) and reboot. Proceed with the installation as normal.
    Update went smooth on my mac mini that way.
    If you don't want to mess with the boot: partition wait for teh fixed CD.
  • »27.05.13 - 21:10
    Posts: 1099 from 2004/9/23
    A fixed iso is now available on all official MorphOS sites!
    Geit
  • »27.05.13 - 21:24
    Yasu
    @§Andreas_Wolf
    Yes, I know that. I'm Swede :P
    I saw this google translated text in a Swedish forum but I didn't know where it originally came from.
    My MorphOS blog
  • »27.05.13 - 21:55
