Posts: 23 from 2003/12/29
Henes wrote:
Please read http://faq.morphos.net/ there is a question/answer about the SuperBundle.
Also please read http://www.morphos-news.de/index.php?lg=en&nid=784&si=1
You are mailing the wrong adresse.
Thanks, but you misunderstand.
I had already registered via the pegasosppc web site, which provided me with no means to access the superbundle http site, so I contacted support (as mentioned in the article you referred to).
Support then auto-emailed
me, telling me to send a mail to the address given above ( support-ml@morphos.net).
I then tried the link given bu
jupp3 above, which provides a registration form. I completed this twice, in fact, to make sure I used the correct details (and purchase date).
Also, the second link you sent is surely out of date now. There has been news since to say the process is now re-activated?
Nevertheless, I have not (yet) contacted sbadmin@pegasosppc.com as mentioned in the article you sent. The registration form said to conctact that address only if I received a warning from registering (I did not).
So I will now try this address. I will also attempt to re-register at www.pegasosppc.com, just in case my old registration is no good.
It seems all in all that this superbundle process has some teething issues...
