Sad about Geneis
    Maurix
    Posts: 81 from 2004/1/8
  • »05.03.04 - 18:53
    antibike
    Posts: 112 from 2003/3/5
    where did you get this "your request is pending"
    error message? if i type something wrong i get only
    "invalid login" ... iam a little bit confused!
  • »05.03.04 - 19:02
    Posts: 159 from 2003/10/24
    I originally had this too. All you should have to do is go to the ftp server directly.
    --Mithalas
  • »05.03.04 - 19:36
  • Targhan
    Posts: 2833 from 2003/2/8
    sorry to hear about this. the superbundle system is under reconstruction. you should contact sbadmin[at]pegasosppc[dot]com if you are having trouble with getting your superbundle serial number.
    :idea:Targhan
  • »05.03.04 - 21:08
    cecilia
    Posts: 459 from 2003/8/30
    I just tried that and it worked for me.
    thanks!
  • »05.03.04 - 22:57
