Posts: 2213 from 2003/2/24
It is a server problem. In passive mode your ftpd must tell to client it's IP-address and in this situation it tells the LAN IP-address, which obviously doesn't work from outside.
I don't know if any native Amiga ftpd has a setting for using it behind router, but some ports like proftpd seem to have option for it. I've modified that setting to wu-ftpd myself, as the sources are available.
Of course port forwarding must be correct in router, but that seemed to be ok already.
